I always put on gloves for work. I have no heated workshop. The temperature as outside. Rust does not attack intensively.
In the morning I was convinced that this was the only solution. Witold https://photos.app.goo.gl/VTz6ETWQhnKyqUQYA https://www.youtube.com/watch?v=hzcKlFjOAoE http://forum.poziome.pl/index.php?topic=1989.0 |
#12
rust
I love Cortec products for corrosion protection. No mess, no clean up. The only problem is when I forget to use them.
https://www.theruststore.com/Learn-about-VCI-W23.aspx
Bill Funk |
#13
Gibbs brand penetrant all around the shop. I try to keep a coat on all tools. Heat in shop helps a lot .Extra fans in the spring thaw.
Andy |
#14
Phosphate
I make my own phosphate solution for steel and iron tools.
I use 88%W/W orthophosphoric acid mixed in the ratio 15% into tap water with a sprinkle of sodium nitrate in it. Works well to protect tools I them dip them in oil and hang them up gives a dry film similar to when they were first produced. Lasts for ages this is well tested - I live in Wales!
Colin |
