Old 01-30-2020, 08:31 AM
MP&C's Avatar
MP&C MP&C is offline
Default Hood modified for breather clearance
One of my former classmates from high school caught up with me a few months back, and had some work he wanted done on a hood for his Tubbed V8 Plymouth Arrow. He said he wanted a more professional job over what was done back then..
Here are some older pictures of the car just to show what we're working on...
He had bought an NOS hood for it some years back, so at least he has something solid to work with.. He said the metal flopped a bit around the opening he cut, so I thought we'd add a wire edge around the opening and make some new bracing on the underside while we were at it. Here's the phenolic dies made for the Lennox to form the new bracing..
Here's a test sample run...
https://www.youtube.com/watch?v=QCoTMs0ANC8
...and a test fit
Next, the bracing we wanted to install needed to go around the bigass hole, and some of the existing brace needed removing.
Our new brace designed to go around the hole... cut in the flat and run through our dies..
And here's about where it will sit....
Old 01-30-2020, 08:41 AM
MP&C's Avatar
Rather than screw up one of the last remaining NOS Plymouth Arrow hoods in existence, let's do a test sample first.. To strengthen the opening, we'll add a 1/8 wire edge protruding upward, which will also help to keep things out.....somewhat. Here's our new dies for the 1/8 wire... This is the "inlet" side...
Side view shows the ramps that will add the joggle
We're using a 22 x 22 piece of 19 gauge for our sample, and folding a 5/16 flange, which needs a bit of stretching to keep things flat. so a rounded hammer on the top of the stump adds a bit of stretch, then a linear stretch hammer and dolly to stretch further and fold things over..
with the flange folded, the sample is run through our dies to form the joggle
1/8 stainless is rolled in our tubing bender/straightener, sized, and TIG welded to form a continuous ring. Then it gets laid in the channel and the flange staked over in various spots to hold it in place using the linear stretch hammer..
Hammering process to fold the flange over. Linear stretch hammer used to add a bit more stretch and to minimize marks left behind..
https://www.youtube.com/watch?v=WWIpwh0zZg4
Finished sample...
….and checked to the brace
With the practice behind us, lets see what we can do to this hood. The outer circle is the mark for our fold, or opening size. The inner circle is the cut for our flange that will wrap around the 1/8 wire..
Getting our tin snips started...
Hole cut with no filing, no sanding, and absolutely no metal "splinters".
If you have issues with tin snips AT ALL, I recommend Bill Gibson's tin snip video... One of the best training/refresher videos on tin snips..
https://www.youtube.com/watch?v=qAOQfUaRZyw
Next, on to the underside. We have four places where these areas of the old structure was cut out that need to go. Opening the hood to see these remnants would just kill the look, so let's see if we can mimic a factory look here.
A piece of 16 gauge was used as a heat shield and using the Meco torch and the barrel end hammer, reshaped the offset back to match the adjacent contour...
That'll do pig, that'll do.
Old 01-30-2020, 08:46 AM
MP&C's Avatar
With the hole cut now we need to fold a flange to wrap around the 1/8 wire. The linear stretch hammer and a heel dolly is used to stretch the flange that will be folded down, then a tipping tool takes the flange down about halfway. Then I needed to get in the thick of things, further stretching and hammering over to a 90* flange, all while checking the crown around the hole to ensure consistent stretch of the flange.
Once the flange is folded, the Lennox is used to add the joggle for our wired edge..
https://www.youtube.com/watch?v=TMk4myTDvmY
Bottom side....
Top side....
Our 1/8 stainless wire "ring" was formed using our tubing roller, the tool shown here in the vise when we were bending fuel line a few months back....
The ring was then sized to fit, ends TIG welded together, filed, and media blasted for paint adhesion. The channel and surrounding area was abraded with some 120 grit and some SPI epoxy brushed into the channel. The wire gets laid into the channel and another brush coat on any bare spots. Then the flange is staked down using the linear stretch hammer to hold the wire in position...
Then the flange is hammered over as we did previously with our test sample.
After our initial coat of primer had dried, we brushed around the perimeter to seal the wire and flange.
Old 01-30-2020, 09:47 AM
Robert perfect work. In a similar way as you did the bonnet reinforcement, I plan to produce a bumper of 2mm stainless steel. I'm glad we're in agreement.
Old 01-30-2020, 10:47 AM
Your old friend is going to love this!
Old 01-30-2020, 11:39 AM
Dr.Mabo Dr.Mabo is offline
Excellent explanantion, thanks.
You gave the answer before I could ask. Because I'm about to form a brace with similar shape and didn't know how. So I have to make a pair of dies. Thanks.
so long
the Doc
Matthias
** Experience cannot be downloaded **
Old 01-30-2020, 04:26 PM
Bevelhead Bevelhead is offline
well structured explanation and post...…..thanks
Rick Jones
Old 01-30-2020, 05:02 PM
Very cool. Thanks for posting, Robert.
Old 01-31-2020, 05:43 AM
dwmh dwmh is offline
Superb job Robert.
David Hamer
Old 01-31-2020, 07:41 AM
metalmarks metalmarks is offline
MetalShaper of the Month October 2020
I enjoyed this, and linking the videos makes it even better! Thanks for the tin snip vid!
Chris
