#1461
That has been my point all along.
#1462
The spartan aspect of your method is what I like so much about your work, Jack.
#1463
Beautiful work, coming together really nice.
Greg
Greg |
#1464
I'm in awe and I may have better tools (shaping wise) but not anywhere near the talent Jack has.
#1465
Thanks for the support, guys. Taking care of some personal business lately and fighting off winter depression. The winters here really take a toll on my attitude. Spring is coming and I'm getting ready to get back to work. I have a lot of catching up to do. Back soon.
#1466
This is a little off topic but I have seen this discussed somewhere on this forum. A friend of mine has redesigned the mechanicals for the hide away headlights on a 67 Corvette and made all the required parts from wood and plastic. He needs to scan and put the data into a format that is compatible with a CNC Mill. What equipment and software is available to do this? The parts are 3D, so a typical program that would be used on a CNC router is no good. That's only 2D. Any input is appreciate.
#1467
CNC data
CAD and CAM systems can be crazy expensive. Not worth buying unless you are going to do a lot of it. A seat of Solidworks and MasterCam can run $20k (US) with all the add-ins.
Fusion 360 can be purchased monthly. Free trial is OK for learning but limited on usable output. Scanners are available for rent. Also services are available to scan and put the data into a usable format. (STEP or IGES) If you are just making one, there are old 3D tracing mills that can copy the wood parts in metal. Gorton is one brand. They are pretty cheap used since it is pretty labor intensive. Jewelers used to use them before CNC. Nice thing is that it can scale the work. Your wood models could be half scale. Good luck.
Bill Funk |
#1468
Thanks, I think his best course would be to find an R&D type job shop and have them do it.
#1469
Scanning is an expensive part of it. That'll get you a file that you would need to import into a 3D cad program to generate a design that can be made using your chosen process. That program could be free Fusion 360 or a 50 dollar membership in EAA and get your free Solidworks with it. After that depending on the part complexity Fusion 360 has some add on's that could possibly generate the machine code. As far as router programs go good commercial programs like the one I use (Router-Cim) can take a nurbs file and generate the 3D code it needs for the machine. That really depends on the program but many do as it's quite common to 3 axis 3D mill on a router. I've played with it a little. Most of the big CAD programs today have capabilities for generation of generic code for machines but need post processors to match your machine for specific code that runs on your machine type.
Ray R |
#1470
Jack,
Is there any rapid prototyping shops around him? These type places should have scanning equipment. If it’s to pricey to have it done by a shop and he’s comfortable with shipping the pieces I can accurately measure them and create them in 3D at work. I make 3D models from measured parts frequently so this should be very doable. Greg
Greg |
