  #51
Old 01-13-2018, 12:01 PM
pplace's Avatar
pplace pplace is offline
MetalShaper of the Month March 2018
Attached are a couple pictures of a "mock up" boxside that I carved out of foam in hopes of what I envisioned to do (this was at the start of the project) I always felt the original stepside box and the almost "trailer" type rear fenders did not fit the style of the front half of the truck at all.
Initially, I added a lower body style line that would have flowed with a somewhat hidden running board below the door. As I mentioned, I later removed the running board idea completely and extended the door down instead.
I don't know if I would have still done the lower body line (which I like) and eventually maybe added a "faux" body line on the bottom of the door and into the front fender opening or just removed it and had the bottom of the box without a body line like I initially did the doors?!?
This is a very quick and crude sketch I did at the start (before carving the foam box) it helped give an idea of what I thought might look good.
Name:  Dodge box very rough sketch.jpg
Here is a picture of the rolling chassis
This is a picture trying to help show the fender to cab jamb separation seam that I came up with. All flush and hidden mounting.
I'm not sure if I added this pic earlier in the thread, but I just like the looks of the project here!
Dane
Old 01-13-2018, 04:25 PM
dave powell dave powell is offline
What type of foam do you use looks like you get a nice finish with it.
Old 01-14-2018, 03:45 AM
That bed is what should have been factory in the first place. Suits the cab perfectly.
Old 01-14-2018, 05:29 AM
I donít know how I missed this thread but what a great build and a real shame you didnít get to finish it. I have to say though, Iím as intrigued by the table itís being built on as the pickup itself. Was it home built or a commercially manufactured one? Iíd definitely like to find out a bit more about it.
Gareth Davies
Old 01-14-2018, 06:28 AM
Fantastic stuff.
I was thinking to make a smooth firewall for my project, but after seeing this, I've changed my mind.
My Project:
Old 01-14-2018, 08:12 AM
pplace's Avatar
That is just regular sheet type styro-foam insulation. Not the easiest to sculpt, but it can work. If you grind on it it wants to “melt” and harden, if you sand on it sometimes it wants to “peel” of some of the surface.
. Thank you, it certainly matches the front way better than the original box
Originally Posted by Gareth Davies
I don’t know how I missed this thread but what a great build and a real shame you didn’t get to finish it. I have to say though, I’m as intrigued by the table it’s being built on as the pickup itself. Was it home built or a commercially manufactured one? I’d definitely like to find out a bit more about it.
Thank you for enjoying the build. The “build table” is more of a crossover item from our collision repair days. It’s an old commercial frame rack / straightening table. It big, flat, strong and level so it was a perfect fit for using as a table to build projects on. It can get a bit tricky at times to work under the vehicle (the rack raised up about 3’ also, but has several crossbars as well as the hydraulic rams to lift it)
I see it everyday, but can’t think of the brand right now. I’ll try to remember when I’m there on Monday.
Originally Posted by 123pugsy
Fantastic stuff.
Thanks. I have to agree, while a smooth / clean firewall is a huge visual upgrade, adding some beadwork or dimension to a panel will really make it “pop” and look a lot more fabricated in the end.
Dane
Old 01-15-2018, 04:57 AM
Bevelhead Bevelhead is offline
Awesome work Dane. You are a real craftsman, and being self taught makes it even more impressive.
You must have a nice dry climate as there was a lot of bare metal and not a tinge of rust anywhere
Rick Jones
Old 01-15-2018, 12:19 PM
pplace's Avatar
Thank you very much! We have pretty decent weather as far as humidity. Hard to say ďdecentĒ when weíve had weeks of below 0 temps down to -20 F. for days on end recently. Obviously in the winter the air is really dry, in the summer we often have the doors closed and the A/C on when it gets too hot & humid.
Dane
Old 02-28-2018, 10:58 PM
MP&C's Avatar
MP&C MP&C is offline
MetalShaper of the month Feb.-11, July - 2018
Dane, beautiful craftsmanship and a great eye for detail! Well done sir!
Robert
Old 03-01-2018, 02:54 AM
neilb's Avatar
neilb neilb is offline
congrats on MSOTM dane, great truck!
Neil
