  #31
Old 02-25-2011, 08:51 PM
wayne080866's Avatar
wayne080866 wayne080866 is offline
Originally Posted by fisherboys View Post
Yes with an edm, these machines are amazing, I think i'll make another set just so I don't have to beat on these. Mark
what is an EDM??
Old 02-25-2011, 09:14 PM
Electro Discharge Machining, Google it and learn more. This is not a subject for this site.
Old 02-25-2011, 09:20 PM
fisherboys fisherboys is offline
It stands for electrical discharge machine. Basically a hole is cut into the workpiece (metal) and the wire, .010 in this case is fed through the hole off a spool onto another spool. The shape is programmed into the machine (cnc) and the wire runs thru the piece cutting it into that shape that has been programmed into it buy the current that is flowing thru the wire, actually eroding the metal. The one used on these parts has a 16'' capacity and was done submerged in water as this extends the life of the wire. This probably isn't a very accurate answer but in a nutshell thats it. I'm sure you could understand it better by looking it up , it's probably on the net somewhere if you know where to look, everything else is. I hope this helped. I always picture it as one of those old 8 mm projectors with the tape doing the cutting. Mark
Mark
Old 02-25-2011, 09:26 PM
Sorry about that, I didn't think on that one. Mark
Mark
Old 02-26-2011, 10:54 AM
tkeen tkeen is offline
Sorry I brought it up, I just wondered how they were made.
Tom
Old 03-11-2011, 11:40 AM
Scrap maker's Avatar
Default beadroller
I'm working on the same kind of thing. I have a HF roller and had a 1/2 die built for a style line on a 32 roadster. I hope to roll half at a time because of the tapered line down the body.. It works the roller hard and you have to have room to flip the panel to come back down. You can see a test roll in this pix. Ray
Ray
Old 03-11-2011, 02:34 PM
Default roller pic
Here is what i have. I run it through both ways and then I have a narrow anvil wheel that i use to raise the center of the bead because it tends to end up a little flat. Ray
Ray
