Old 05-10-2010, 11:03 PM
McClary's Avatar
McClary McClary is offline
good job and thanks for the pictures...
Old 05-11-2010, 05:54 AM
Marty Comstock's Avatar
Here is yesterday afternoon's work. After a good lunch, we got busy aligning the posts and starting at the indide door edges made some tacks. made sure the height and flow of each opening worked, then tied things together. measured the widths, and using the donor roof made filler pieces to start reattaching everything together.
first corner being welded
Name:  s dutch making first welds on post 19.jpg
comparing original doorframe to new height of roof. WOW
Name:  t comparing original door to new height 20.jpg
dogs love trucks, even unfinished
Name:  v dogs love trucks 22.jpg
Here is Dennis working on making filler pieces for the front gap
Name:  w dennis making filler pieces 23.jpg
Ben welding side filler
Name:  y ben selding side filler 25.jpg
and the rear filler made by Ben
Name:  z rear filler.jpg
The fast work is done, now the fitting, welding of the posts is fairly easy, next is the roof and getting the cab corners to flow with one another, as well as making the bodyline behind the door work. The door frames will be last, they are easy especially with the donor pieces we have.
Marty
Old 05-11-2010, 09:36 AM
Gleeser's Avatar
Gleeser Gleeser is offline
Metalshaper of the Month, May 2010
Cool man, keep em comin'!!
Grant
Old 05-11-2010, 09:47 AM
hehehehe, the original idea of keeping the rear window the same size? No Go on this chop. the amount of chop reduced the area so much the rear window frame wont fit, and even if it did, it wouldnt look porpotional. Not going to mail slot it, but still taking 4" or so out of it. John and Dennis are having fun with this one, you oughtta hear them
Anyway, here are some looky loos...
Dennis laying out the cut lines
Name:  y dennis cutting rear window 25.jpg
Cleaning edges of paint and primer
Name:  z cleaning up the rear window 26.jpg
the sides tack welded and now to make the filler piece
Name:  za rear window frame being reassembled 27.jpg
Marty
Old 05-11-2010, 03:43 PM
gettin quite a bit done today, got the rear window shortened, welded back together abd starting to weld it in place now after having some fun with the arrangment of the panels
Dad has been working on the doors, getting the pieces from the donor doors and getting them to flow in the openings.
started seeing what itll take on the cab corners to make them flow as well.
if yall wanted an update on the hour, sorry, but at least we are showing more than youd see on a tv show
LH cab corner relief cuts
Name:  zb cab corner relief cuts 28.jpg
RH cab corner relief cuts
Name:  zc cab corner rh relief cuts 29.jpg
test fitting rear window
Name:  zd test firt rear winder 30.jpg
planishing some welds on the rear filler
Name:  ze planishing some welds 31.jpg
Ben filing the body line
Name:  zf ben filing the cab line 32.jpg
Dennis welding on the rear window frame
Name:  zg Dennis welding on rear window frame 33.jpg
welding in the rear window frame
Name:  zh welding in rear window frame.jpg
stay tuned!!!!
Marty
Old 05-11-2010, 04:40 PM
tmedley's Avatar
tmedley tmedley is offline
I am amazed at how quickly this came apart and is going back together. Awesome job guys! I love watching this thing progress.
Tony
Old 05-11-2010, 05:12 PM
CARS CARS is offline
What? No continuous oxy welding??? I thought you guys would just tack it all up and weld it up in one pass
(looking good. You're having more fun than I am painting )
Christopher Rathman
C
hris'
Autobody
Restoration
Service
Old 05-11-2010, 07:05 PM
Ever see a 20 year old die of a heart attack? Me either, and I dont wanna
Marty
Old 05-11-2010, 08:43 PM
Go offline for a couple days and look what happens...geesh.
Old 05-11-2010, 10:44 PM
Justin C's Avatar
Justin C Justin C is offline
Looks great Marty. I have a great idea, when your done with this one bring your crew and head west. I have lots of work left on my truck. I may be able to find some coffie if that helps. You could bring the dogs too!
Justin C
My two and a half year olds solution if i dont have something..( go buy some)! Thats my boy!!
