Old 10-24-2014, 03:04 AM
Lister1
Guest
Posts: n/a
Default Door panel
I made this door panel 2 millimeters too tight because I forgot to add the thickness of the sheet. I need 1200 mm, but I have 1198.
Is there any other solution to fix except hammer and chisel. I know that it is possible to weld the edge, but I'm not happy with that solution.
Old 10-24-2014, 08:00 AM
Marty Comstock's Avatar
You can make a new one.
you can straighten the edge, planish the mark out and rebend, but I can make a doorskin faster than fussin with that.
Jus my .0002
Old 10-24-2014, 09:04 PM
ekdave1962's Avatar
yep weld the edge , lead it or make it again seem to be the only options , have you fitted door to check gaps yet as 2 mm is only 1 mm top and bottom
Geelong victoria
Australia
Old 10-25-2014, 11:14 AM
RatRockx's Avatar
RatRockx RatRockx is offline
MetalShaper of the Month July 2013, Feb 2018
The bright side is that now you have learned to cut to size after shaping.
Joris Rockx
www.rockx.net
Old 10-25-2014, 01:30 PM
If I had this problem, I'd try adjusting it over a stake or dolly, 2mm ain't much to move, it's quite a common issue I have, adjusting edges until I'm happy.
Martin
Old 11-05-2014, 08:33 PM
The Old Tinbasher The Old Tinbasher is offline
Default Adding to edge
I would hammer and dolly the edge once it's folded over. You should be able to stretch the edge 1mm. on each side.
TB
John Poole
