Old 04-16-2018, 06:56 PM
MetalShaper of the Month July 2017
Default How to bead the center of this fender?
I'd like to do a small bead down the center. I can only go 1/8 inch high or maybe a bit more, width maybe 1/2 inch or so. Any suggestions on how to do it with simple hand tools on simply made tools?
In case you're wondering I decided to do all the shaping on the wheel. It's 80 thou on the edges where there's no wheeling and about 60 thou in the middle.
Jeff
Old 04-16-2018, 07:03 PM
Ron Naida Ron Naida is offline
MetalShaper of the Month Nov 2015
Do it on your ewheel
Ron
Old 04-16-2018, 08:01 PM
Simply take your top wheel off.use a shaft equal to the bolt that keeps your top wheel on, bend it to clear the cradle then put two round rollers on it, space them out to the distance required. As for the bottom .... use a shaft with a welded washer with a blunt edge position it in the middle of the two rollers and then squeeze
the two with the guard in position
PS do this with a few passes...........................
Old 04-16-2018, 10:48 PM
MetalShaper of the Month Nov. 2018
Nice job all round Jeff!
Old 04-16-2018, 11:10 PM
Barry Barry is offline
May 2012
If you're looking to do it very simply you could chase it in by hand. Perhaps making up some sort of guide to keep it neat - take a look at how guys are doing similar on reciprocating machines, and then translate that to a manual operation. So maybe a wood template of the profile across the short direction of the top, that will allow you to feed the fender through. Create a groove in the centre to match the bead you want (metal inserts on the edges will keep it crisp), then make up a chasing tool.
The operation is likely to need an extra pair of hands - one guy hammers/chases while the other feeds..
Old 04-17-2018, 12:02 AM
bobadame bobadame is offline
I made this tooling to bead fenders with my wheeling machine. The o-ring in the center of the bead is there to help follow a line.
Bob
Old 04-17-2018, 03:32 AM
Good work. Or you can use hard rubber or polyurethane and simply get a nice shape without a precise tool.
http://allmetalshaping.com/showthrea...ghlight=fender
Old 04-17-2018, 07:21 AM
RockHillWill's Avatar
Very clever, Mr. Adame. You are a gifted machinist as well.
Imagination is more important than knowledge - Albert Einstein
Click below for ordering or status info on Tommasini Ewheels:
http://www.mantiquesresto.com/RestoredItems/Tommasini/TommasiniWheel.html
Old 04-17-2018, 01:45 PM
I like the permanent black line, Bob. Good noodling.
Old 04-18-2018, 05:13 PM
Thanks for all the suggestions. This is a great website!
I combined a couple of the ideas that were mentioned and came up with this. Hammer powered hand chaser?
I think it's going to do the job. This trial is on an off cut from the fender.
Jeff
