Old 08-18-2015, 06:55 AM
Default Drilling a larger hole in a washer
Does anyone have any ideas or tips how you can securely hold washer that needs a larger hole drilled into them, With-out damaging the washer itself.
I don't have a Lathe!
On smaller hole sizes like 5/16, my Snap on spot weld clamps work great, but larger sizes won't go.
The bench vice marks and sometimes the drill bit will rip the washer right out, marking it to the un-usable stage.
Any Suggestions?
Cheers John
Old 08-18-2015, 08:05 AM
KAD KAD is offline
Default drilling
Take a block of wood drill a hole into it just smaller than the washer outer diameter.
Then cut the block in half strait through the middle of the hole, now get two strips of sandpaper and glue them to the blocks to line the half holes.
Use these blocks to hold round objects in a vise without marring the outer edges.
You can also make multiple holes in the block of wood and line them all with sandpaper the same way this allows you to hold multiple size washers or shafts with only one block.
I use a small strip of duct tape to keep them attached to the vise, I tried cutting ledges and such but ended up just using duct tape and it worked well enough for how many times I use them.
(Just my thoughts, not in any way to infer that this is the only way to do it...nor that I'm right or smart or disagree with anyone else's way of doing things.)
Kirk
Old 08-18-2015, 10:13 AM
tbody321 tbody321 is offline
Default drill
take a wooden dowel that is slightly larger, place in vice and press washer against dowel..then tighten vise, the dowel deforms and allows vise to grab washer.... dowel prevents washer from moving...
works for me
Tony
Old 08-18-2015, 12:32 PM
Default Enlarging washer holes with die grinder
Any Suggestions?
Cheers John
Since I sometimes have to enlarge holes in hardened washers, I don't set up to drill them. I have copper and brass jaw covers for my bench vise so the washers hold tightly on one edge while I use my ancient 25k rpm die grinder and a variety of carbide burrs to enlarge the holes to the scribe lines. I don't even think about it any more - even on thick large hard washers.
Where the hole is large and the washer is small I only do one side of the hole and re-set the washer to do the other side.
Old 08-18-2015, 01:04 PM
bobadame bobadame is offline
You could tac weld it to a plate in a couple of spots. Center it under the spindle, clamp it Jed, drill it then grind it away from the plate.
Bob
Old 08-18-2015, 01:15 PM
Pokie's Avatar
Pokie Pokie is offline
When the hole needs to be just a bit larger, I'll pinch the washer in the vise and use a tapered reamer from both sides to open it up. The nasty part about using a drill bit is if the hole isn't much bigger, the drill bit will bite and tear it out of the vise. When the hole size is close, a reamer is your best bet, at least that works for me.
http://pokiespages.com/
Old 08-18-2015, 01:18 PM
on the top of your vise jaws drill 4 small equally spaced holes - 2 on each jaw. Now put some drill rod in the holes. The washer will be held by the drill rod on it's outer edge and the top of the jaws keep the washer level.
I hope you can visualize this.
Jim Russell
Old 08-18-2015, 03:22 PM
Ranchero50 Ranchero50 is offline
Just sandwich them between two pieces of scrap plywood. There are several variation on this theme depending on how many and how accurate you need to be.
The most accurate method is to clamp the bottom sheet to your drill press and to spot drill it half the thickness of your washer with a bit that is the same diameter as the OD of your washer. Then set your washer in the hole, screw on the top piece of wood and drill through it to make your larger hole.
You can go deeper with the OD drill if you have a stack of washers to drill out but it takes more pressure to keep them from turning in the stack.
Hope this helps.
Jamie, the kid who took his toys apart...
Old 08-18-2015, 05:02 PM
Marty Comstock's Avatar
find yerself a well used 6 jaw chuck for bench mounting purposes. I have a couple that I use for knockaround stuff like this, they are lifesavers.
Marty
Old 08-18-2015, 05:42 PM
60 convert 60 convert is offline
Default washer id
Another thing might be to clamp it like previous and use a step drill.
Jesse
If you can't do more with less you will probably do less with more. Be Creative
