  #1181
Old 03-26-2019, 03:36 AM
Love that idea of switching between SA and DA between grits. Thanks for passing that on.
Old 03-26-2019, 05:53 AM
neilb's Avatar
neilb neilb is offline
not sure if you have covered this but what parking sensors are you using jack? i ask as the vw amarok uses chrome faced pdc sensors in the rear bar. also has sensor holders that are double sided taped to the inside of the bar. has a nice flush fit look to them.
Neil
Old 03-26-2019, 07:51 AM
I'm using the sensors from the CTS but the grommets won't work. I was not able to find anything that had the 60 degree angle that this bumper has. I was even willing to paint them silver if I found some that would work. The Amarok has a flat vertical surface so the grommets would be 90 degrees. If I used them on the Cadillac, they would be searching for airplanes.
Old 03-26-2019, 10:10 AM
Have you considered 3D printing the parts?
James
Old 03-26-2019, 10:39 AM
Far too many contours in the mirror stands. There isn't a straight line on them anywhere. The mirror buckets are a radiused cone and sit about 10 degrees off the axis of the stand. The top of the stand tapers downward from front to rear in a compound tapered curve to match the buckets. The base of the stand is convex curved where it mounts to the body and the axis of the top and bottom surfaces of the stands are offset.
It would take far too much time to work all that out and test fit dozens of attempts. Plus they need to be strong. They need to be made of aluminum.
I don't have access to a machine shop any more so this is the best way. The foam sands down very easy and fast so I can test fit on the car in a few seconds by taking just a couple steps over to the car. Some things are just better hand made and time is becoming a factor. In August it will be 4 years on this car. I'm not getting any younger. Git er done!
Old 03-26-2019, 05:08 PM
Is the foam sturdy enough to put sandpaper, grit up, on the body of the car and "lap" the mirror base to a close fit?
FWIW
Marc
Old 03-27-2019, 07:44 PM
FWIW
Good idea Marc, I hadn't thought of that. After the stands are cast, I'l give that a try when I'm doing the final fitting.
Old 03-27-2019, 08:44 PM
I consider coming up with an idea that impresses you an accomplishment!
Thanks, You're for real (Obviously!)
But, witnessing how your mind works, you'd glommed onto it soon enough!
Regards,
Marc
Old 03-29-2019, 05:16 PM
I got the bumper polished. It was a couple days work but it's done. I cut the temporary brace off and the bumper sprung open, which I did expect but it moved a lot. I managed to get it to bolt to the car but I have to figure out how to rebend the curve into it without heating it. Overall, I'm satisfied with the results.
Old 03-29-2019, 06:49 PM
Any expert welders out there want to give me some advice? On the lower edge of this bumper I have a 1 1/2" round tube running the full length. When this was welded up, the bottom edge of the sheet was laidover the tube and welded full length. I think this is primarily what caused the bumper to spring when I released the temporary brace. Did the long bead of weld along the tubing shrink when it cooled and draw the tubing to a flatter shape than original? If so, would I be able to draw it back in by welding a bead along the tube on the back side directly opposite of the first bead?
I don't thik the top is a problem. The tube along the top edge is only 1/2". I was watching Jim when he was welding and noticed that when he was welding the top, the whole tube was going red from the heat. It may not have bent like the lower one.
I guess the simplest way to ask my question would be; Can I make a controlled bend lengthwise on a piece of tubing by welding a bead full length along the tubing?
