I remember the first time I posted a photo it took me all day to figure it out. Then when I finally did get a picture up it was so small that you couldn't even see it.
It is a pain in the but, after you figure it out it ends up being pretty easy. I have always admired your work Tim, so it will be great to see some of your projects.
Thanks Johnny! I hate to admit how stupid I get with these little magic boxes, but they kick my butt all the time. I gave up on Autocad, I can never get past simple brackets and tabs. I have a buddy that does it for me, so the learning curve went flat right there. I would much rather bang on some metal than spend hours and hours getting nowhere!
Tim Young @ www.irrationalmetalworks.com |
#13
Oops that didn't work
#14
This has been a test of the CARS operating system, had this been an actual emergency, instructions would have followed
100_5302.jpg (I was having picture issues last night. Since it happened here and at MM, I am just going to assume that it had to do with a Vbulletin upgrade or ???)
Christopher Rathman Chris' Autobody Restoration Service |
#15
Chris, I think the problem with the pictures was the subject in the picture. The Eckold Piccolo is probably the problem. Ship it to me immediately so I can fix the problem, it will be returned to you when the problem is fixed. May take a long time but don't worry about that. Please send the operating instructions and all tooling with it.
#16
Joe, it's for sale. I forgot the name of the owner already ( ) but it's at Dan Pate's (route56wingnut) shop right now. I used it at his MM on Sunday to build a lid for my bulk feed bin.
100_5321.jpg The broken original aluminum one is in the front, new 19 ga one that I formed is in the back. It shrunk it like a charm. Used a tipping wheel to make the outer lip and planished it smooth.
#17
Chris, thanks but I probably can't afford it. Those usually go for big bucks.
#19
Stan, all I did when I edited your post was position the cursor where I wanted it, in this case at the end of your text, select the paper clip, and select insert attachment. That makes the photo show up. If you have a bunch of photos attached you can do them one at a time or do a 'attach all' function which will be at the bottom of the paperclip list.
Neat car...what is it?
#20
stan............... Last edited by slobitz; 04-26-2010 at 09:16 PM. Reason: add pic |
