Old 12-22-2009, 06:29 PM
hlfuzzball hlfuzzball is offline
Verrrrrrry interesting !
Thanks for the info.
Tom
Old 12-22-2009, 06:55 PM
I stand corrected, 3003 alloy is used for can bodies.
So 3003-H18 (Temper) is used , that's why it's so rigid and strong for it's thin sheet.
I Googled 3003-H18 and found this chart:
Mechanical Properties
Tensile Strength
Yield Strength
Elongation
Brinell Hardness
ksi
MPa
ksi
MPa
% in 2"
(50mm)
3003-0
16.0
110
6.0
40
30
28
3003-H12
19.0
135
18.0
125
10
35
3003-H14
22.0
155
21.0
155
8
40
3003-H16
26.0
180
25.0
175
5
47
3003-H18
29.0
205
27.0
190
4
Fabrication Guide
Weldability
Corrosion Resistance
Formability
Machinability
Mpa
TIG
Resist.
3003-0
AAEAAA
3003-H14
ABDAAA
3003-H18
ACDAAA
So, I assume the can stock reverts to 3003-0 after annealing with the torch and then can be easily formed.
Tom
Old 12-22-2009, 09:40 PM
tdoty's Avatar
tdoty tdoty is offline
Thanks for the info. I stand corrected as well! I would guess the drawing and ironing operations would have an effect as well, thus the decreased ductility after forming.
Since I have never used 3003-H0 (to my knowledge), I can't comment on how it compares. However, if properly and fully annealed, it should return to a "dead soft" state.
Tim D.
Old 12-27-2009, 08:32 PM
Peter Miles Peter Miles is offline
Another possible source for thin aluminum is aluminum printing plates, as used in newspaper plants, etc. The alloy may be too still to form well, however. A quick search showed that some of it is only 0.15 millimeter = 0.005905512 inch thick.
Old 12-28-2009, 04:45 AM
Einar_S Einar_S is offline
Did you figure out how to get the coating off?
I have lots of these plates, but never found out how get the coating off.
Akershus (Follo) Norway. Einar (at-sign) sjaavik (dot) no.
