Old 06-10-2012, 08:59 PM
ronnieculpeper ronnieculpeper is offline
Default 18ga. question
hello everyone, Im new here and forgive me but I'll be asking a lot of questions,so here goes.Im making new floor boards for my 50 plymouth buisness coupe and Iwas wondering if there is a specific type of 18 ga. sheetmetal I should use. For the time being I'll be using mostly hand tools with the help of Dave Gardners video. From what Im gathering ,there may be more than one choice as to which is easier to work with. thanks,Ronnie
ronnie thomasson
Old 06-10-2012, 09:46 PM
MP&C's Avatar
MP&C MP&C is offline
Ronnie, hot rolled steel normally has a mill scale on it which is a pita to remove. Cold rolled steel normally has just a bit of oil film on it to protect from flash rust, but no mill scale. The cold rolled IMO would be the better choice.
Old 06-11-2012, 12:37 AM
Custom Metalshapers Ltd Custom Metalshapers Ltd is offline
MetalShaper of the Month June 2014
Default steel choice
Hi Ronnie,
Cold Rolled is good but if your doing this job over a few months consider getting sheet with a protective coating so it doesnt turn orange with surface rust before the job is done. we have a few names for it like Zintec and Electrogalv. different retailers have different names but the coating is light grey in colour and can be welded through. dont get it confused with straight out Galvanised sheet.
Tony Katterns
Old 06-11-2012, 06:02 AM
Marty Comstock's Avatar
The specification you are looking for is 1008 or 1018, the last two digits representing carbon percentage. Hot rolled, usually notated as A36, has a carbon content that is a tich higher, and its tolerances are much wider, Hot roll should never be a consideration.
There are further designations that folk will use, such as DQ or DDQ, draw quality or double draw quality, and in MY opinion, it is not wont the effort in locating unless your supplier happens to have it on hand. It is said to shape easier, and that may be true, but in MY experience, not enough so as to make a large difference.
So, Cold roll 1008 or 1018, DQ or DDQ is what you want to ask your supplier about.
Marty
Old 06-11-2012, 09:01 PM
Thanks everyone, this helps me narrow down my search ,and Marty it was the DQ AND DDQ that was throwing me off as I've seen it mentioned before leading me to think I should ask someone before I purchase so thanks again
ronnie thomasson
