Old 11-02-2012, 12:33 PM
JIMSPSYCLESHOP's Avatar
JIMSPSYCLESHOP JIMSPSYCLESHOP is offline
Default Motorize my bead rollers
rotary former.jpgHi all,
I'm one of the new guys. I did a search for motorized roller conversions but only came up with a thread that concentrated mostly on the Harbor Freight power drill set up. I want something a little less crude than that but I'm no master of electrics either.
The two units I want to motorize are:
Eastwood bead roller
PEXTO type rotary style bead roller/former
(see photos attached)
I have a nice 6 amp foot pedal from a Husqvarna sewing machine (US current). I'm thinking about 14 inches for the top pulley wheel and maybe two inches for the small one. Prefer to use V-belt pulleys as I can get them for nothing at scrap yard. As far as motors, I'm not opposed to using a power drill as I have a vintage spare Milwaukee variable speed drill I could cannibalize.
I have a small lathe so I can turn bearings/bushings ect.to fit the drive shaft or re-bored pulleys if I need to.
Pictures of other conversions would help.
James Starkey-Naperville, Illinois
'Don't waste my time & I'll return the favor' - My Grandfather M.R.C. 1888-1963
Old 11-02-2012, 01:55 PM
Bill Gibson's Avatar
Bill Gibson Bill Gibson is offline
Here ya go...
http://www.youtube.com/watch?v=YqErTwU1rSE
Bill
People will do things that nobody else will......
Old 11-02-2012, 02:06 PM
Thanks Bill,
That's the one I already saw & it's in the search files. I like his guide fence a lot and I'll likely may a similar one but I was looking for a set-up a little less 'home made' looking as far as powering the roller. JImmy
Old 11-02-2012, 10:08 PM
A couple Sheet metal covers/belt guards, and a coat of paint and nobody knows what's under there.... I just never take the time to do that stuff for my own tools... as long as it works that's all I need it to do.. It's the customers stuff that has to look nice...
But I know what you mean.. it is nice to have a professional looking piece of machinery in the shop when prospective customers walk in....
Luckily there's enough motorcycles in the shed that I can point to, to show my work..
Bill
Old 11-03-2012, 09:34 PM
Mike Hendrix Mike Hendrix is offline
You could use a small electric motor mounted anywhere, even directly on the shaft and a variable switch for your foot pedal and your all set. build a couple covers and racks for your dies, some paint and your in business. As for the smaller roller you are on your own. I haven't built one of those.
Old 11-03-2012, 09:58 PM
tdoty's Avatar
tdoty tdoty is offline
Direct driving the shaft takes a bit of horsepower.....1/4 horse will do it, 1/3 horse is better. Mine was a 1/15~ish hp with a 4:1 belt reduction and still needed a bit of help sometimes.
No need to worry about wizardry, just use a variable speed motor (or not). I prefer 90vdc myself. A 3-phase motor and a vfd will work too. More than one person has used a fixed speed motor.....just remember you can't slow down for corners or speed up for long boring beads. DC or the vfd option allow for easy reversing. Single phase motors do not allow easy reversing.
A gear reduction is a must! Mine was 87rpm with a 4:1 belt reduction, resulting in 22~ish rpm at the dies......even with 2" dies, that is moving pretty quickly!
Tim D.
Old 11-03-2012, 10:54 PM
I have. 1/4 HP 3 phase gear motor on my smaller bead roller 98:1 ratio with 698 lbs of torque. I'm using a 1/4hp 110 volt VFD it is a great combo.
http://allmetalshaping.com/album.php?albumid=125
I have a 1/3 HP DC gear motor on my deep throat bead roller it also works great! Both have variable speed forward and reverse
http://allmetalshaping.com/album.php?albumid=33
If I only had one choice it would be the 3 phase with 110 volt VFD.
Old 11-04-2012, 11:16 AM
Dutch Comstock Dutch Comstock is offline
You want to be able to run your bead roller as slow as possible so that you can do real trick quality work. Straight work you will also be able to acurately at a fast speed , If you are going to do a lot of trick work you will also be making trick dies and hard surfacing the outer edge as cold roll dies will deform quickly if used a lot. You will also end up wanting to stiffen up yoour frame if you are doing trick work. Dutch
Dutch Comstock
926 Shells Bush Road
East Herkimer,N.Y. 13350
(315)866-3034
comstockmetalshaping.com
Old 11-04-2012, 08:26 PM
Jim Stabe's Avatar
I used a HF 12v winch driving through 15/48 tooth sprockets giving between 6 and 7 RPM at the rollers, cheap and plenty of power. The winch has a spool disconnect feature so I also have a handwheel that I can use for intricate work.
Jim Stabe
Under construction - MGB roadster widened 11.5", Corvette C-4 suspension, 440 hp LT1 V8, T-56 6 speed.
Pictures here:
Part 1
Part 2
