Old 09-02-2013, 02:19 AM
type550 type550 is offline
I had some time over the weekend to try and make a panel for my spyder. Unfortunately I only have hand tools (besides a drill and a jigsaw) so everything is shaped and bent by hand. I am happy with the finished result, but it would be nice to get crisp right angles on the folds. I just need to tweek it to fit properly to the car and then move onto the other side...
At the end of the day, when it is painted, I want it to look like this original one...
Andrew
Old 09-02-2013, 02:59 AM
Doug M Doug M is offline
Andrew,
I'd say you came really close.
with hand tools you can tighten the crease with a wood "V" and a made of wood chisel work from the inside of the fold, OR clamping the panel between 2 stiff boards or angle iron pieces and tap on another board along the fold from the outside.
I don't see a need but you're there and know more what you want.
Doug
Old 09-02-2013, 03:03 AM
Thanks for the tip Doug. I sandwiched the sheet between two pieces of timber and viced it then slowly bent it by hand. I didn't want to hammer it as I didn't want the dents to clean up after - another board is a great idea!
Andrew
Old 09-02-2013, 07:26 PM
Desoto Desoto is offline
MetalShaper of the Month March 2014
Hi Andrew,
I had a 550 replica a few years ago lots of fun built on a VW floor pan. To the top of the windscreen total height was a metre. Getting in and out was fun and impossible with the soft top fitted. Looks like you will have lots of fun with all the curves.
Cheers,
Ash.
Ashley Briggs
Old 12-24-2013, 01:50 AM
Things are slowly progressing with my spyder panel fabrication. I have formed my sill panels and also side panels under the cockpit. I am going to line the whole inside of it with aluminium now which shouldn't be too difficult except climbing in under to make the panel templates.
I have got myself a simple english wheel which the previous owner has kindly modified to make it work better. I have been spending some time getting used to it and it will do the job for the purpose I need.
I have the confidence now to try and make a tonneau for the cockpit. I have measured it up and made a pattern for it. I will use the wheel to get the slight convex shape, and I have ordered a stretcher/shrinker to help with the curved edges.
My challenge is creating the rounded curved edge closest to the driver. As it also tapers off, i would like to know the best way of going about it to create it. Please remember, I am very much a novice, but will give anything a go and hopefully to perfection!
Andrew
Old 12-24-2013, 12:13 PM
That is coming out FANTASTIC!
