  #1701
Old 02-18-2021, 06:51 PM
When I was making the carbon fiber engine side closure panels, I didn't have much time to get detailed pictures so I'll go into detail here. When I made those, I was using a mold that was removed after the panels cured. I laid up three layers of carbon fiber cloth and two separate applications of resin. Those are stand alone panels. Their strength is built in.
These cowl panels will remain in their "molds". The ABS and carbon fiber will bond together as a unit so I won't need to use multiple layers of cloth.
I think I mentioned last time that this method is strictly for cosmetic pieces. There are completely different procedures for structural c/f parts that require either pressurized injection molds or vacuum molding and very carefully measured quantities of resin.
The finished ABS panel below has been wiped down with acetone to remove any mold release agents that might be left behind, then lightly sanded rough with 80# on a DA. I masked off the area with the vent/drain holes and it's ready.
Attachment 58848
I laid the panel over some c/f cloth and taped off the cut lines leaving plenty of excess material along the edges. Be very careful handling the cloth. It's a loose weave and if it snags, it will pull the strands out of alignment. Cut the cloth with scissors down the middle of the tape and leave the tape on both the piece you're using and the roll so they won't unravel.
Attachment 58849
Next, carefully lay the C/F cloth over the panel and tuck in or relief cut where needed.
Attachment 58850
Epoxy resin is preferred for C/F, it has a longer work time than polyester resin typically used for fiberglass. Depending on temperature, sunlight (UV), and humidity polyester resin can start kicking in just a few minutes. With epoxy resin you have anywhere from 20 minutes to an hour. C/F doesn't saturate quite as readily as fiberglass, so the extra time and work with a spreader and brush helps.
Pictured below are two separate kits of epoxy resin. The smaller 16 fl oz kit was left over from the side panel work. The 64 fl oz kit is fresh. Two different brands and sizes but the same product.
If you're looking to buy this stuff beware that there are a few unscrupulous characters out there selling it by the ounce (weight). Be sure the label says fluid ounces (fl oz). Also, prices vary wildly. You should be able to get a 64 fl oz kit (2 - 32fl oz bottles) for around $40 USD. About 65 cents per ounce.
Attachment 58851
You'll need: 2K epoxy resin kit, mixing cup (the resin doesn't eat up these plastic cups), a flat roller(sqeezes out bubbles and voids), a 90 degree corner roller, brush and spreader, and some acetone for clean up. Lacquer thinner will work also.
Measure accurately and mix thoroughly. Follow the directions that come with the resin. Proportion is vital. If you under catalyze, it won't cure and you'll have an unsalvageable mess on your hands and have to scrap it and start over.
Attachment 58852
Pour it on, spread it out, work the bubbles out and let it cure overnight. Clean up is easy with acetone.
Tomorrow I'll trim the edges and sand lightly before putting on another coat of resin. If this were a flat part like the side panels, I would just level the part on the bench and pour the resin on and let gravity do the rest. Since these panels are all different shapes, I'll have to brush on a few layers letting them kick one layer at a time.
Attachment 58853
Super helpful procedure explanation, with cautions, hints, and sourcing.
Awesome tutorial, Jack.
Big thanks!
Old 02-19-2021, 06:39 PM
Hi Jack
Thanks for sharing your very detailed procedure with us.
Your project just keeps getting more impressive by the day!
Old 02-20-2021, 07:34 PM
I put a second coat of resin one both halves of the cowl and they look pretty good as is. This stuff lays up pretty thick so I really don't need anymore.
Once the resin is spread out, I use a torch to clear the air bubbles out.
The resin must not produce any flammable fumes cuz you can get in pretty close with the torch without any problems. The surface lays down flat and no bubbles.
Old 02-22-2021, 02:41 PM
dwmh dwmh is online now
Very clever Jack. I would never have dreamed of taking a torch to it. We never stop learning. Thanks for all your posts on a great project.
David Hamer
Old 02-22-2021, 03:29 PM
Originally Posted by dwmh View Post
...I would never have dreamed of taking a torch to it.....
You can also just blow on it but with a larger part like this you risk hyperventilating, passing out, and waking up with the part bonded to your face.
Everything in me screams "Chemicals and open flames don't mix!" But it doesn't seem to be hazardous. I think it is the CO2 that does it.
Old 02-23-2021, 04:17 AM
Great information Jack and a thread that will need it's own index as there's so much useful stuff here. Thanks for your consistency in posting to the group it's much appreciated.
Phil
Old 02-23-2021, 08:46 AM
brisner brisner is offline
Question
jack do u get nervous when u experiment::
Bob Risner
Old 02-23-2021, 11:22 AM
Risk and uncertainty are always present. Risk can be managed, reduced, or eliminated. Uncertainty doesn't worry me.. Most likely everything I try has been done before by someone. Just find out if he's in the magazines or the obituaries.
Old 02-23-2021, 08:07 PM
Jack, your just fine. In the woodworking world, when using epoxy for that 1/4 in glass like finish, this is a common technique. Great job and info.
George
Old 02-23-2021, 09:39 PM
jack your skill set is right on par with the ring bros. what makes your build so impressive is u are a one man show working out of your garage where as they are pro builders with abig shop.your caddy is just as amazing theirs
Bob Risner
