  #241
Old 12-10-2023, 02:04 AM
So, the second fender... Was looking even worse, with rust and some dents:
So as usual I took it to bare metal:
I beat it back to shape with Dolly/Hammers and the english wheel, like here:
And for the front part I had a NOS part but decided to keep it for somebody needing a bigger repair, and to use it as a template for my patch panel :
And then adjusting it:
Tacked:
Then the light bowl:
And in primer! As with the other one, only let the back bottom to be adjusted/welded when positioned on the car:
Just with some grips for the motivation :
Old 12-27-2023, 02:54 AM
While I was there playing with the fenders, I adjusted the A-pillar protections mudguards and welded the fixations that were missing:
And then I played with the bottom part of my front mask..
Making the template :
And then in metal:
Starting with the english wheel:
Taking shape :
And then more work :
Before/after:
And welding :
Old 01-20-2024, 02:48 AM
So, here are the next steps on the front mask !
The openings around the nostril were not satisfying so I took care of it:
And done:
After that I built the part behind the nostril, mine were too far gone:
Lots of cutting, adjusting, and of course adding the 3 tabs for the nostril fixation (a 60 only feature !):
And ready to be mounted:
Putting back the horns' support:
Welding the pocket behind the nostril:
And after a blasting session..some epoxy primer and we have a saved front mask :
Thanks for following !
Old 01-20-2024, 07:13 AM
Good progress, always good to reach the paint stage.
Old 01-20-2024, 03:25 PM
I donít know which is more impressive, your work, or your work place!
śrugo nunquam dormit
Old 01-20-2024, 10:06 PM
Never any disappointments with your posts, Antoine. Itís looking great!
Old 02-24-2024, 01:17 PM
Thanks a lot guys ! So kind of you!
So, next I decided to take care of my engine hood. It was globally in a good shape :
But in details had a lot of dents, rust,..well the usual issues
So I first prepared some patch panels:
And this one:
Stay tuned!
Old 02-25-2024, 12:17 PM
Antoine, I've worked on a lot of rusty cars, mainly MOPARs from the 50s and 60s which just dissolved automatically. That said, you've done and are continuing to do a great job.
I'm impressed.
Old 03-22-2024, 04:02 AM
Thanks Kerry!
Well, let's continue the update !
I then unskinned the hood:
Lots of rust being set free :
And here we are:
Old 04-02-2024, 03:51 AM
So, I then started on the frame:
And welding:
The other corner needed some work too :
And welding :
Then I blasted it and some primer/rust protection Paint:
