Old 09-04-2020, 09:12 PM
abarthdave abarthdave is offline
The exercise mentioned about putting a crown into a 12" square and then making it flat again will help you learn exactly what needs to be done to get it to where it needs to go. (I really need to try this myself, so yes, I'm guilty of bypassing something so important)
I think I will show this exercise at my upcoming meet.
is there a Youtube video of that somewhere
Old 09-05-2020, 03:45 AM
Never seen one before. I've just read about it on a couple of forums.
From what I remember reading:
The key is to put crown into a panel evenly as the first part. Maybe an inch high. The crown should be the same both ways with the four corners touching the table. Then, wheel the sheet perfectly flat again.
Old 09-05-2020, 09:10 AM
Originally Posted by WCRiot View Post
I made some progress the other night. Looking at the first picture I wheeled in a different direction than i had been. I used a larger radius wheel, i believe it was the 6inch.
This helped some.
But then look at the second picture. I went tot he Shrinker to try and get rid of those wavy spots along that edge. And that created a pinch line and screwed up all my progress.
So i went back at it and got it pretty close again. I will do what MP&C says and hope that bring things together.
I almost feel like i need a flat wheel to flatten out that edge that would be closer to the wheel well.
Attachment 57378
Attachment 57379
When shrinking and stretching metal, it needs to be a gradual transition.
The shrinks you made only pulled at the edge of the panel, and did not shrink farther into the panel.
Stump or tuck shrinking would go deeper into the panel.
Looking at the top photo in this post the shrinks need go in to the left end of the orange horizontal lines.
A small amount of shrink at the orange lines.
More shrink as you move out to the edge. Think of it like a slice of 🥧, one shrink at the inner point, and two shrinks out one inch, three shrinks out two inches, four shrinks out at the crust.
You need to make some radius gauges to help see the flow and arrangement.
Get your Wheaton’s box a ✏️ and scissors, to cut a number of these to match your fender. 3or 4 of them from the fender mount area towards the wheel opening and a couple the long way of the fender. If the fender from the other side of the vehicle is in better condition make them off of it. Label them and mark their position on the fender and your new panel.
By using these you can see where your low spots are (outside surface), those areas that need to be stretched.
You are making progress keep trying and watch closely what is changing.
Only do a small amount of shrink and or stretch and recheck to see what has changed.
Old 09-05-2020, 06:13 PM
That exercise for flattening a curved piece was on a John Glover video
ærugo nunquam dormit
Old 09-12-2020, 03:30 PM
WCRiot WCRiot is offline
I can positively confirm this as i purchase the book and did not find this lesson in there. An easy read though...
Instagram @RealRiotRacing
Old 09-12-2020, 03:42 PM
Default Simple question
First picture shows a radius gauge on the actual part i am trying to replicate. It measures about 5.0in radius.
So if i use my 4.5in Radius anvil and i just keep rolling in the same direction on this test sheet, won't the sides of the metal come down and eventually match the lower anvil? Meaning, if i use a 4.5radius anvil can i eventually form a 4.5in radius on this test panel?
Old 09-12-2020, 04:21 PM
Yes, due to "springback" in the metal, the panel will lay down going through the compressive pass and immediately spring back up to a lesser radius.
Harder metals have more spring-back.
I have seen some panels (work hardened 2024 T3) with a radius of 24 inches being shaped with a lower roll having a 30in radius.
... and with metal that hard there were zero marks ... on our polished thin aircraft top skin.
Old 09-13-2020, 06:36 PM
Default Removing shape exercise is in John Glover's book as well....
This is the second half of John Glover's exercise I referenced in post #11: removing shape. Below is a scan of page 30 from John Glover's self-published book, hope I am not violating any copyright rules.
SO much more to be gleaned from this book other than this simple exercise. His stories are also quite engaging and worth a read.
Once again, I wholeheartedly recommend this book to anyone interested in learning the wheel...
Mark from Illinois
