  #41
Old 02-26-2022, 07:20 AM
I take my hat off to you. You are one brave guy.
Old 03-03-2022, 04:14 AM
Thanks a lot David!
So, next I fixed the clutch tube.
First the part on the firewall, I don't know what a PO was thinking with this thick piece?!
So I removed it and found a damaged firewall:
So removing what is damaged:
Making the patch:
Welded:
And the front fixation, cut the access :
The issue:
Welded (pic was ongoing, I welded the whole length but forgot to take a picture):
And closed:
Old 03-10-2022, 05:49 AM
So, I then worked on my engine side panel:
Then the necessary holes:
Then the sealing guide:
A before-after:
And in place :
Old 03-30-2022, 06:27 AM
So, I think the next step was quite logical..the battery tray
I did built it by hand couple months ago:
So it was time to adjust and weld it, first the bottom part:
And then the top:
All done and all fits great:
I then found one last hole on the firewall:
That I welded close:
And now we have a nice engine bay/right long:
Starting to look good!
Old 04-01-2022, 05:20 AM
I have more to share with you
This corner was ugly:
So I decided to take care of it:
And the outside part, before:
Starting with the bottom part:
Welded:
And the top part:
And here we are:
Old 04-06-2022, 08:28 AM
Next step was the bottom of the B-post..here you go :
Empty space:
Home made part being adjusted:
Old 04-06-2022, 12:08 PM
You’re far more ambitious than I am, Antoine!
Old 04-06-2022, 02:33 PM
Antonie, they should send you a medal from Porsche. You should take a picture of the garbage you swept off the floor. That car probably doesn't have a healthy place. It drove somewhere on the beach or in the winter on salty snow.
Good work, of course, but I don't think you expected it to be so bad. The car looked good. It's scary.
I'm sending you medals for bravery .....
Old 04-17-2022, 01:42 AM
Thanks a lot guys! Very appreciated!
So, then comes a big step..the quarter panel!!
I made it myself of course..first, adjustment:
And then cut, tack welded:
And then welded:
My door gap is so much better than it was!
Planishing:
And done:
The last missing part was the small bracket at the front of the wheel:
All looking good:
Thanks for following along,
Old 04-17-2022, 05:37 PM
Romantic Comedy Car Crash Romantic Comedy Car Crash is offline
It looks like you've done this a few times!
With all the small spots you're uncovering have you considered stripping the whole body and sending it to media blast?
Rocco
