Old 12-12-2014, 12:36 PM
ojh ojh is offline
Default Silicon bronze tig'g
I haven't done much welding with silicon bronze and I'm trying to use it now. I am having a problem 'seeing' it, I have a greenish flame and theres lots of carbon soot around the puddle.
I'm using a 1/16th 2% thoriated toungsten, standard smallish cup, 100% argon, upped the flo to 9ish, DC current, no freq, welding on clean mild steel.
Do I have the wrong settings or is the greenish flame & carbon normal.
thanks, oj
oj higgins
Old 12-12-2014, 01:30 PM
Could be you have brazing rod instead of silicon bronze rod. That would do that for sure. Otherwise you could be just way over heating the weld.
The Rod Doctor,
Richard Crees
Old 12-12-2014, 01:50 PM
Do you have a whitish residue, also? If so, it could be that you have used a yellow brass filler, instead of SiBr. Best to verify your filler before anything else.
Old 12-12-2014, 02:33 PM
dwood dwood is offline
One other possibility is that you accidentally touched the tungsten with the silicon bronze rod and 'coated' it. Happens to me occasionally. I use a stationary 1" belt sander to "re-point" the electrode.
But from your description . . . I tend to agree with the others in that you might have a brass rod instead of silicon bronze.
Don
Old 12-14-2014, 08:29 AM
ojh ojh is offline
I think you are right dwood, I'm blind in one eye and can't tell how far I am from the puddle and must've contaminated the toungsten.
I do have silicon bronze rod and as I worked with it I got better and the weld became cleaner, it is an odd color and has surface contamination.
I bet the RodDoc is right too, it wouldn't surprise me that I am way too hot and am cooking the rod. I haven't been able to work on it for a couple days - have customers stuff that needs to get done - but maybe this evening I'll be able to experiment some more with it.
oj higgins
Old 12-14-2014, 11:21 AM
Default For what it's worth
After reading about it elsewhere, I have experimented with Sil bronze TIG set on AC, but with the arc balance set at low cleaning levels, between 10-20%.
The cleaning portion of the arc helps with the wet-out of the puddle, it seems. It also yields nice clean beads.
Mark from Illinois
Old 12-15-2014, 09:43 AM
ojh ojh is offline
Interesting, I'll give that a try too.
My camera/computer aren't talking or I'd post a picture or two esp the surface contamination - it might be normal or it might be overcooked.
oj higgins
Old 12-15-2014, 10:32 AM
I’m not so sure you can use silicon bronze as a filler rod for chrome plating steel. The guy I prepare parts for will not let me use anything except tig or gas welding on steel parts, mig welding is too hard , it doesn’t polish out correctly. I don’t know about silicon bronze but I’d certainly talk to your chrome shop before using it on those headers. ~ John Buchtenkirch
Old 12-15-2014, 05:28 PM
Chris Bspoke's Avatar
It will chrome plate fine John but needs someone really good at polishing for plating as in my experience the steel will under cut where it meets the silbronze
Chris cant
Old 12-17-2014, 10:13 AM
Exactly my point, the differences in hardness don’t allow the joints to be polished to perfection . He would be better off filling his low seams with steel weld by using gas or tig. From what I’m told the problems are caused by the EPA closing down the cyanide copper tanks. I’m told the cyanide copper plating was the Bondo of the plating businesses, it had high buildup that covered over many sins / mistakes when followed up by an experienced polisher, however the fumes are deadly. I think in the USA the cyanide copper tanks only operate illegally now or that just might be my state, New York. I still stand by my earlier advice, he should call his platter first to get an opinion from the person who actually has to do the job. ~ John Buchtenkirch
