#531
![]() Quote:
Thanks, but I think you're way ahead. Short list of remaining items: Chop top Chop doors Major door overhaul to get the window slot straight for one piece glass New hood Repair rear fenders, add 1-1/2" and weld to car Rear valance New chassis Inner front fenders Paint the El Camino as my daughter thinks it's too drab when we go to cruise nights among all the bright colored rods. This winter for the El Camino so will be losing Rod time. |
#532
Back to the front clip. I needed to reinforce the fender edges as they were buckled in in a couple of spots. I was going to fill them with a 3/8 stainless rod, but that would probably rust too fast. I opted for a 3/16" diameter rod welded to the edge of the lip. This still left the trough for water to run down and out of the rim.
#533
Some of you may remember warning me of the damage that would have incurred to the paint job if I had of continued with the body mounts in the first pic here. The plug welds would have totally cracked the paint eventually.
The only other place available was the thin rim around the headlight opening. I formed 6" wide strips of satin coat steel to the shape of the opening...never mind...the pics are self explanatory...... |
#534
The halogen light kit comes with a nifty grommet to pull out to change the bulbs from the rear. The drilling may seem hack, but the buckets are so thin, the holes popped thru in seconds and only took about five minutes. Thin means it filed easily to shape as well.
#535
This gets us to Sunday past when I hit the front clip with some epoxy all around.
#536
![]() Quote:
![]() Very interesting points on your list and very well done ones scratched off. Thanks for the detailed updates and hurry back to thy rod! ![]()
"The punishment for desire is the agony of unfulfillment." |
#537
I had a fine fella, without mentioning any names Matt, mention something about using a split back window when I chop the top. I thought, "what?", nah, ain't gonna happen......
Well, after 8 hours on the road and a couple of bucks less in the wallet and we got us a new window frame. A few months in the molasses and it came out pretty good. |
#538
I considered chopping the top in the basic way when same said fine fella made a Photoshop of the roof lowered without touching the B pillars or door tops. Hmm.....I like the sound of that.
The scale of roof length, door window height, and door height itself below the window opening seems to be fine as is. Need to lose that box at the rear of the roof as well. I sliced down the A pillar and took 2" out of the windshield opening for an inch and a half roof lowering. After and before shots.( In the wrong order) |
#539
This is where I'm at. Time for my attempt at wheeling panels approximately one foot wide down each side.
A mock up of some scrap ally I had laying around. |
#540
I would approach the pancaking of the roof by wheeling the existing roof panel along the sides where most the the crown is. That would release it and let it down flatter without needing a filler piece.
Is that what you plan to do?
