Old 05-05-2009, 11:19 PM
Default Aluminum skin for hard-lid by Lone*star**
This thread was originally posted on the old site. The original thread with photos can be found here:
http://allmetalshaping.forumsdot.com...php?f=17&t=167
Please make all new posts for this thread on the new site...that is HERE. We will be working to get the photos moved over.
Lone*star
Post subject: Aluminum skin for hard-lid
PostPosted: Tue May 05, 2009 4:45 am
This Ford Mainline Ute is another ongoing build, it come in as a rectification from another high profile workshop, with numerous examples of poor build quality that I have been correcting.
This task is to replace the hard-lid skin. The previous attempt was pop riveted on to a tube frame, and it had an overlap join half way back. ops:
The skin had no shape wheeled in and had numerous buckles and oil can areas.
I am using .062" Aluminum, grade 5005, H34(half hard), unfortunately the sheets that are available in my area are only available as 8'X4', which doesn't span the area I need to cover.
I have begun shaping the first sheet and trial fitting it to the frame. there were several ways this could have been joined, I chose to have the join down one side as it would be easier to reach to weld and work the weld area.
After the car returns from the trim shop, I will trial fit the lid to determine the width for the other sheet and the 3/4" turn down around the edge
_________________
Stuart (Lonestar) Smith
Lone*star
Post subject: Re: Aluminum skin for hard-lid
PostPosted: Wed May 06, 2009 3:40 am
Offline
User avatar
This was all I got done today, too many interruptions, at least it is going ahead
_________________
Old 06-02-2009, 04:14 AM
lone*star's Avatar
lone*star lone*star is offline
Well, I was able to complete the hard lid today. After the wheeling operation, a little work with the slapper was needed on the weld area to lift some low spots.
The aluminum skin was bonded to the steel frame with Fusor 108 metal to metal adhesive.
Name:  Theo Mainline 167.jpg
Stuart Smith
Sheet Metal Whisperer
Old 06-02-2009, 07:47 AM
That really came out great Stuart! Low crown panels like this give me more difficult than high crowns.
