Old 05-14-2021, 09:44 PM
william.owen william.owen is offline
Default 1978 loadstar 1700 4x4 cab
Hi,
Here's my 78 loadstar 1700 build detailing sheet metal work etc. Going to be my next service truck to replace my current bullnose ford. I am in the process of extending the cab 16".
Pretty green with sheet metal, so apologies for some of the workmanship! \
Full build thread is at https://www.binderplanet.com/forums/index.php?threads/78-1700-4x4-build.146704/
Sharing with you guys to hopefully pick up some knowledge!
150044184_452477495935314_3760915083825560412_n by wild0, on Flickr
received_2864785340406771 by wild0, on Flickr
20210406_153747 by wild0, on Flickr
20210406_160111 by wild0, on Flickr
20210406_165222 by wild0, on Flickr
20210406_095800 by wild0, on Flickr
20210408_150001 by wild0, on Flickr
I borrowed my neighbours brake to bend the 90 then beat the offset in w/ franken pickle. I have since got a brake of my own
20210408_151349 by wild0, on Flickr
20210408_180807 by wild0, on Flickr
William Owen
Old 05-14-2021, 09:50 PM
it took a while to figure out how to go about cutting the cab and not having it fall apart. I'm not big on plans so just sort of winging it as I go.
Ideally I would of found another cab, it would of made it much simpler. But alas here we are
20210410_145804 by wild0, on Flickr
20210410_162324 by wild0, on Flickr
20210410_162332 by wild0, on Flickr
20210410_193113 by wild0, on Flickr
20210410_190657 by wild0, on Flickr
20210411_133958 by wild0, on Flickr
20210411_141938 by wild0, on Flickr
William Owen
Old 05-15-2021, 05:07 AM
Thank for sharing.
Looks like you are doing well with it all so far.
Old 05-15-2021, 05:45 AM
It looks like a good choice for the field. Good work.
Old 05-15-2021, 09:29 PM
Wow, that's a TRUCK! What kind of service work do you do and why the extension?
Old 05-16-2021, 06:51 PM
I do general mechanical on equipment & marine. Also welding & line-boring. Little bit of everything. Where I am it rains a whole bunch, and it gets pretty old pretty quick having a single cab truck, trying to keep your raingear, laptop etc dry.
I've been intimidated by and have very little experience in any body work, so this is sort of a project to get some more skills. Plus I plan on keeping the truck for a long time, so might as well do it once and do it right!
William Owen
Old 05-16-2021, 07:07 PM
I was back and forth for a couple weeks with myself debating on if I should get an English wheel or not. So I settled on getting a box and pan brake instead.
I've wanted a brake forever so this was the right time to do it. Plus I will be building a service body once the cab is done.
I just passed geometric development in trade school so there was a lot of beating my head against the bench trying to remember how to layout. I am very ADHD. Case in point; my left and right hand floor pans I did the bends the wrong way so the beads are opposite
20210507_165842 by wild0, on Flickr
20210507_174513 by wild0, on Flickr
20210508_191856 by wild0, on Flickr
Promptly I realised that I would have a heck of a time doing the panels without a wheel so my missus ended up paying for half for my birthday present.
The roof was pretty caved in and dented. I dollied the majority out before cutting but didn't bother going all the way. The cuts I made so the extension would mostly be in one plane, and minimise/hide distortion post welding.
I haven't decided if I'll put a roof support in or not.
20210513_144830 by wild0, on Flickr
20210513_150903 by wild0, on Flickr
I wasn't able to get the last bend in the drip rails with the brake so I used some 1/2" square and chisel to form it. Shrunk inside w/ slices and welded back together. Took around 6 hours and a few attempts to get the drip rails right. 20210513_154143 by wild0, on Flickr
20210510_152938 by wild0, on Flickr
20210510_152932 by wild0, on Flickr
20210513_154132 by wild0, on Flickr
William Owen
Old 05-16-2021, 07:16 PM
This was the first wheeling I'd done. I was quite pissed off by the end of it and ended up tacking it in and calling it a night. With a bit of finessing it straightened out ok. The roof sprung out a bit post cutting which was expected. I was going to make a form or brace to hold it in shape, but it wasn't really in a great shape before I cut it. Cut first measure later.
Currently in the process of welding the roof out.
20210516_123455 by wild0, on Flickr
The side pieces turned out much nicer. Drivers side which was the first one I put a bit too much crown in so little bit more work on the dolly pulling that out.
20210516_125206 by wild0, on Flickr
20210516_125200 by wild0, on Flickr
20210516_125611 by wild0, on Flickr
20210516_140731 by wild0, on Flickr
2021-05-16_04-12-25 by wild0, on Flickr
William Owen
Old 05-17-2021, 06:45 PM
Right on ! The floor tunnel looks great i would have bought a break first also . more useful especially with floors and inner structure . you used hot rolled that stuff is tough to shape . Good Job
James
Old 05-17-2021, 10:56 PM
James
14ga hot rolled too for the trans tunnel! The floor and inner sides are 16ga. I wish I had the brake before I did the floor.
Hard to find anything thinner up here. Our steel supplier wanted a 25 sheet minimum for 18ga CRS. I ended up getting 2 sheets from a supplier out of town.
William Owen
