  #31
Old 06-06-2022, 09:59 AM
william.owen william.owen is offline
I spent a while trying to position the d150 club cab windows where they looked right, but I couldn't find a suitable spot due to the different cab angles etc.
Actually I was perfectly fine to start welding them in, until a person commented that the angles didn't match up right. This threw a wrench in the works and had me questioning everything!
20220325_131705 by wild0, on Flickr
20220325_181724 by wild0, on Flickr
I think it will be the right choice, just a lot more work. All the IH glass is flat, yet the d150 windows were curved. So it would look funny in the long run I think.
I decided to make window frames. This was the last bit of fab work I did on the truck cab in march/april. I needed to take a break for a bit to catch up on work and my sanity.
20220326_163408 by wild0, on Flickr
I tried making the frame profiles in one piece but it was out of my skill set.
20220401_151444 by wild0, on Flickr
20220401_161343 by wild0, on Flickr
William Owen
Old 06-06-2022, 10:14 AM
In between then and now I started making a bead roller. I was initially just going to power my existing one, but I didn't want to spend time and money mounting an electric motor on something that I generally hated the appearance of.
I re-used the shafts, gears and bearing blocks from my old bead roller. I think I will make new shafts from 4140 size as the existing shafts are neither straight, or of decent quality.
The drum switch is one I had leftover from my lathe. Initially I was going to use a foot switch for forward and reverse, but the foot switch I got was only rated for 7amp at 125vac, which would end-up with welded contacts with 90vdc 1.5amp I believe. I couldn't scrounge the appropriate relays to do safe and reliable forward/reverse with the foot switches.
Rotation direction is selected with the drum switch, and then the foot switch is using NC contacts to pin 7 and 11 inhibit rotation provision of the Bodine FPM speed control, which is 24vdc and .5amp switch requirements.
I found a suitable drive gear in the box of lathe parts I believe its 14 DP. Bored it out and made a press in reducer to fit the 3/4" keyed gear motor shaft.
The stand is from a 20 ton screw jack I pulled out of the scrap yard a while ago. Drilled and tapped to mount to 1/2" base plate
Overall it works well. I have a month of so work to catch up on before I can get back to working on the cab. So until then!
20220605_183435 by wild0, on Flickr
20220605_183529 by wild0, on Flickr
20220605_183536 by wild0, on Flickr
20220605_183500 by wild0, on Flickr
William Owen
Old 06-06-2022, 05:58 PM
I like it! What is the electric motor drive from?
ærugo nunquam dormit
Old 06-06-2022, 07:04 PM
Nice bead roller for sure.
Old 06-07-2022, 06:14 AM
Love the ornate reinforcement!
