  #691
Old 07-17-2022, 10:34 AM
I had the young lad bring the wheel to my home finally as I wanted to get a smooth tail panel wheeled up.
I'm no expert so there are a lot of ripples, but much better than hand tapping.
The home made tool is just two scrap bars with a washer a bit thicker than the panel.
Old 07-17-2022, 10:44 AM
Edge reinforcing is a 3/16" stainless round bar.
You'll notice that in no way did I try to make the wire edge look perfect.
One gets to a point where there is more frustration sometimes than enjoyment.
About five coats of epoxy to make sure inside the curled lip is coated well.
And scariness, attaching the first fender to the car.
At the front of the fender, I have it mostly welded from the inside since I will be filling the outside in places and creating a rounded corners with filler lower down.
Old 07-17-2022, 10:50 AM
Where I am today.
I got it cleaned up a bit yesterday but still needs a lot of planishing. My arms are too short or the fender it too big. Well, one of those anyhow.
Old 07-17-2022, 03:46 PM
Pehr Pehr is offline
Nice work and thanx for sharing.
Pehr Norström
Old 07-18-2022, 03:54 PM
rockable rockable is offline
You are definitely giving that old Mopar some style, Pugsy! It's gonna look nice when you're done.
Rock. Able
Old 07-18-2022, 10:23 PM
pato1 pato1 is offline
parts of it are looking great right now!!
Pat
Old 09-25-2022, 11:28 AM
Thanks Gentlemen.
Old 09-25-2022, 12:04 PM
I got the passenger side welded on.
Had to drill a hole for dolly access. Not sure which side to put the gas fill nozzle on. Anyone have any solid reasons for why one side would be better than the other?
Tail pan needs a channel on the top, which I did in pieces of course.
Of course it shrank after welding. Lots of heat yet again.
Corner bits.
Old 09-25-2022, 12:14 PM
I had the guys bend me up a filler piece. It was marked from the bottom for a tip line.
Home made trunk popper. No outside latch or key.
Old 09-25-2022, 12:19 PM
Got a functioning deck lid. And yes, I opened and closed it a bunch of times.
https://www.youtube.com/watch?v=KwJgCY3GiHc
