Old 08-02-2021, 03:21 PM
tjratz tjratz is offline
Default linear/ radial stretching
Now while I know the difference between linear and radial stretching (at least I think I do). How does one know when to use either one? What are the clues that a piece needs to be stretch either radially or linearly?
TJ Ratzlaff
Old 08-02-2021, 03:30 PM
TJ. Don't look for science and names. Learn to make paper templates. They will show you all directions. Paper is the basis. It will show you the direction.
Old 08-02-2021, 05:52 PM
Hi TJ
if you wanted to make half of a beach ball, (hemisphere) where the crown is the same in all directions you would use radial stretch. Starting with a metal disk, the most stretch in the middle and gradually less as you move outward. A round tool is used to cause this kind of stretch. The metal will increase in surface area north to south and east to west. Most shapes are created with a blend of shrink and stretch to keep a more uniform metal thickness. In this case the outer portion would be shrunk.
An example of linear stretch would be if you wanted the hemisphere to have a flange around the outside so that you could fasten it to a flat surface. This would require that the flange be the same circumference as the sphere at the bend line but would need to be longer at the outer edge. the stretch zone needs to be like the shape of a piece of pie. very little stretch at the point and a lot more out at the crust. this could be done with stretch dies in a mechanical stretcher or by thinning the metal with a rounded chisel or chisel end of a body hammer into a shot bag or a firm rubber pad. you could also stretch into a void cut out of stump.
Old 08-02-2021, 06:17 PM
Well said Jaro!
Read the paper pattern and find the answers there,
Cheers Charlie
Old 08-03-2021, 03:42 PM
Long narrow shapes like channels and angles that need to be curved (outwards) are shaped with linear stretch techniques.
On this part, above, the stretch dies leave marks showing their distinct imprint (track). This circle started out as a straight 90 flange. One edge was stretched back and forth very evenly and the curve eventually formed into a circle. Even though the marks now radiate from the center of the circle, the stretching was done using linear dies and only moving in a linear direction whilst keeping the shape 90deg to the flange, at each point of die contact.
Large areas (lily pads/reverse shapes/saddles/flips) which need curved surface areas lifted up are stretched with radial methods.
The "paper pattern," which has been previously mentioned here, shows how the shape does radiate up and out. In metal, this will become a radial shape that is also reversed/flipped.
Resulting radial shape.
See radiating lines of stretch marks, coming from center of panel and radiating out to the shaped, lifted edge.
A modified linear stretch die was used - in a radial method.
If you simply shape "back and forth" on a panel like this you will discover that "bunching" happens at the ends of your passes. See the little one on the right end?
Using radial shaping techniques, consciously, makes for even radial shapes - with no bunching.
and etcetera :
For myself, I have only begun to discover the shapes I really want to make, so my understanding is yet incomplete.
Old 08-04-2021, 02:46 PM
All very useful and helpful insight and knowledge. Thank you everyone for clearing it up for me. I greatly appreciate it!
TJ Ratzlaff
