Old 12-01-2010, 01:42 PM
ELpolacko's Avatar
ELpolacko ELpolacko is offline
Default Model A firewall
We have a build going on here that the owner has let me use my creative talents on. Actually tough to do these days!
The stock firewall was not going to work with the 57 Olds engine even with moving the radiator forward three inches. Most guys build some sort of recess or flip the firewall around, but this build deserves so much more.
Since the car has a '32 Ford vibe going on I wanted a firewall that sort of fit the theme we had going on. One of my guys, Bob started by making some poster board patterns.
After the patterns were made we discussed how to bead roll it. We wanted a pattern similar to the '32 but a bit smaller and simpler to fit the simpler lines of the A. I had already done a bead rolled firewall on my fathers 37 Ford, by the time I was done closing the ends and flattening things out I could have made a stamping.
Dad's firewall:
Bob and I sketched a few things out on the layout pattern and I started drawing up the die to cut out on the CNC, weld it and punch it using my pressbrake.
This was the first test, it turned out very well but did rip the tight pointed ends a bit. The punch was softened a bit and a few more test pieces run before we ran through the real firewall.
Old 12-01-2010, 01:47 PM
ELpolacko's Avatar
The pattern turned out fantastic.
We then welded a strip around the firewall to attach it into the cowl with fasteners to be determined later. Also the ends of the toe board kickout were capped and a blister added to clear the steering gear.
Then installation into the cowl. We just have some sheetmetal screws holding it in. We are contemplating riveting or screws, just not there yet.
Oh, then we went nuts on the bracing for the steering gear and brake/clutch pedals...
Old 12-01-2010, 02:13 PM
tobyflh tobyflh is offline
That looks great!! Rivets or some kind of nice screws would look good. Also what kind of steering box is that?
Old 12-01-2010, 02:14 PM
german8rcoupe's Avatar
german8rcoupe german8rcoupe is offline
Thumbs up
Very nice work.
Ross
If at first you don't succeed....skydiving is not for you.
Old 12-01-2010, 02:16 PM
ELpolacko's Avatar
Steering gear is late 70's Mopar, probably from an Aspen.
Old 12-01-2010, 03:08 PM
keith keith is offline
Wow, That is beautiful.
Keith Daleen
Sedalia,Mo.
Old 12-01-2010, 04:05 PM
Very nice!
Old 12-02-2010, 12:52 PM
REALLY nice work Steve. I'm lusting after your plasma table....
Please put your name in the signature block of the User CP. Everyone will forget your name after a while.
Old 12-02-2010, 02:17 PM
rexrogers rexrogers is offline
The fire wall looks great. thanks for posting it a great use of the equipment that is available to you.
Rex Rogers
www.realhotrods.com
Old 12-02-2010, 02:23 PM
ELpolacko's Avatar
Sig added
Thanks much guys!
Steve Szymanski
www.IndustrialChassisInc.com
Phoenix, AZ
